MADjestic Posted September 21, 2006 Share Posted September 21, 2006 Hi, I was going through the following example: $HFS/demo/helpcards/dop/popsolver/DOP_EXAMPLE_popsolver_MatchShape.cmd I then decided to bring the simulation data to object level by means of Object Merge SOP. The problem was that when I bring the popobject1/Geometry object Quote Link to comment Share on other sites More sharing options...
craig Posted September 21, 2006 Share Posted September 21, 2006 It's pretty simple - just append a Delete SOP, and put "$N" (without the quotes) in the Group line at the top. That will remove the last primitive, which is the particle system, leaving the geometry you want. Quote Link to comment Share on other sites More sharing options...
MADjestic Posted September 21, 2006 Author Share Posted September 21, 2006 Arrrgh! that wasn't too obvious, or was it... Thanks you, craiq =) Quote Link to comment Share on other sites More sharing options...
Jason Posted September 21, 2006 Share Posted September 21, 2006 Arrrgh!that wasn't too obvious, or was it... Thanks you, craiq =) You could use a Delete SOP, check "Numbler/Enable" and Type "Particles". This will delete all present Particle sytems. Quote Link to comment Share on other sites More sharing options...
MADjestic Posted September 23, 2006 Author Share Posted September 23, 2006 You could use a Delete SOP, check "Numbler/Enable" and Type "Particles". This will delete all present Particle sytems. I bet this should be included into Craig Zeroni Quote Link to comment Share on other sites More sharing options...
craig Posted September 24, 2006 Share Posted September 24, 2006 Good idea - and no, I don't think this is in the helpcard. Quote Link to comment Share on other sites More sharing options...
