eilidh Posted April 19, 2020 Share Posted April 19, 2020 (edited) Hey! I'm fairly new to Houdini and have been trying for hours to work this out! I'm making a greeble tool want to be able to scatter assets on top of the greeble. The (placeholder) assets are in their own subnet and are all in the one object merge within the greeble node network. Is there any way I can randomly switch between these objects while they're in the one merge? So that then user could add more objects into the merge as well using the UI without having to edit things inside of the greeble node network? Edited April 19, 2020 by eilidh Quote Link to comment Share on other sites More sharing options...
davpe Posted April 19, 2020 Share Posted April 19, 2020 take a look at this video for one possible approach to this situation: or this one for a solution using switch SOP: (at around 6:30) Quote Link to comment Share on other sites More sharing options...
eilidh Posted April 20, 2020 Author Share Posted April 20, 2020 This has been a lifesaver, thank you! The first video worked perfectly, similar to what they did in the video and worked in the object merge by packing the geometry before merging. Quote Link to comment Share on other sites More sharing options...
