pyro shelf tools to SOPs
bunker
Houdini's pyro shelf tools create 3 nodes on /obj/ level. I really hate that and got tired of copy+paste+renaming nodes...
I wrote a simple shelf tool python script to fix that. It works for PyoFX and Sparse PyoFX shelf tools.
hope someone finds it useful :lol: and if anyone can improve that script or make it more generic, please post it here...
import re
# move dopnet to SOPs
def dopnet2sop():
  # find first dopnet (assuming there's only one)
  # replace relative external paths to absolute paths
  dopnet=hou.nodeType("Object/dopnet").instances()[0]
  sourceNode=''
  for dopnode in dopnet.children():
    for parm in dopnode.parms():
      nodepath=parm.evalAsNode()
      if nodepath!=None and len(nodepath.path().split(dopnet.path()))==1:
          # convert to absolute path
          path = parm.evalAsNode().path()
          parm.set(path)
          # find the pyro source's path
          if dopnode.type().name()=='volumesource':
            sourceNode=hou.node(path)
  sopDopnet = sourceNode.parent().createNode("dopnet")
  pos = sourceNode.position()
  sopDopnet.setPosition((pos[0],pos[1]-1))
  hou.copyNodesTo(dopnet.children(),sopDopnet)
  dopnet.destroy()
  return sopDopnet
# set dopnet as reference in dopnode's path
def fixdopio(dopnet):
  di=None
  for dopio in hou.nodeType("Sop/dopio").instances():
    dp=dopio.evalParm("doppath")
    dn=dopio.evalParm("dopnode")
    r = '`chsop("doppath")`'
    a = re.sub(dp,r,dn)
    dopio.parm("dopnode").set(a)
    dopio.parm("doppath").set(dopnet.path())
    di=dopio
  return di
# move import nodes to SOPs
def moveDopioNodes(sopDopnet,dopio):
  dopIoParent=dopio.parent()
  # find highest node on y axis
  x=0
  y=0
  for i in dopIoParent.children():
    pos=i.position()
    x=min(x,pos[0])
    y=max(y,pos[1])
  ioNodes=hou.copyNodesTo(dopIoParent.children(),sopDopnet.parent())
  diffx=x-sopDopnet.position()[0]
  diffy=y-sopDopnet.position()[1]
  for ioNode in ioNodes:
    pos = ioNode.position()
    ioNode.setPosition((pos[0]-diffx,pos[1]-diffy-1))
  dopIoParent.destroy()
# remove unused Output dop nodes
def removeUnusedOutputnodes():
  for out in hou.nodeType("Dop/output").instances():
    if len(out.inputs())==0:
      out.destroy()
# move dopnet and dopio to SOPs
hou.setUpdateMode(hou.updateMode.Manual)
sopDopnet=dopnet2sop()
dopio=fixdopio(sopDopnet)
hou.setUpdateMode(hou.updateMode.OnMouseUp)
Edited by bunker
  • Like 3
