Grouping unshared "in-line" edges
konstantin magnus
Hey :)
Just something I would do in a wrangle or group expression SOP
//  running over points:
@group_entryPt = neighbourcount(0, @ptnum)==2;
then you just add a group promote, converting it to an edge group (with the checkbox ticked of only include complete entities (or whatever it was called, don't have hou open atm :P))
Edit:
That should at least work for the single extreme edge-entry points.
For the doubles and up, you probably have to do a bit more,
but generally speaking, using the amount of neigbours of a point and the amount of vertices on a point together should work on "2d" geometry, I think ;)
but you may have to create the groups directly in vex, to avoid grouping unintended edges.
But to avoid selecting edges on both sides of a corner separately, you would have to add additional logic (as soon as you allow those double-edge entry points)
if its only 1 and 2 edges you probably can get away with case-by-case handling, if you want to go up to an arbitrary amount of edges, its just will have to get more complicated I guess :P
Edited by acey195
