[solved]after multiplying vel by denity, vel bbox still 1px larger. Why?
Hiya,
In order to make the bounding boxes for my density and my velocity volumes the same size, I thought multiplying vel by density would be a good idea.
In theory it was...
After this multiplication, the vel volume's bbox ist still 1 px larger than the density bbox, and that goes for every dimension. Why is that so?
Edited by Whatsinaname
solved
it's because in the old Smoke Solver vel is voxel face sampled and density is voxel center sampled so their actual voxel grids are not only misaligned from each other, but also all 3 grids within vel are misaligned from each other, there was a reason for that historically
you can sim vel as center sampled by changing Smoke Object/InitialData/VelocitySampling to Center
but new Smoke Object (Sparse), whether you sim sparsely or not has it set to Center by default
Edited by anim
  • Thanks 1
