Angular Constraint
Nimrod7
Hi folks,
I am trying to use the Angular Constraint with rbd objects to control the direction an object lands (e.g. a cone always ending up facing up, no matter how it falls), but I am failing to understand how the constraint works.  The docs also are confusing for me without an example.
I have set some goal geometry, which I set in the constraint, but other rdbs doesn't seem to land in the direction the constraint geometry is facing.
Here is my network.
Thanks in advanced for any help.
  • 3 years later...
