Emit RBD Hero Object from particle or geometry
ovidiu
Hello , i have one issue with RBD Hero , it is possible to emit the same RBD hero object multiple times from particle or any objct without having to import the rbdobject node multiple times? Not packed prims  only RBD Hero Object to have good floating objects on fluid tank. Becouse i try paked, prims and explode ater while, after few frames even when i play with feedback scale from Solver. Can you help me with a hit how i can manage this? Thanks.
Edited by ovidiu
