Rotations using Orient attribute and Cross Product
noumiere
Hi all i'm going over some concepts such as rotation and the orient attribute by doing some simple examples.
I would appreciate if someone could clear up the confusion I'm having or point out where I've gone wrong
Simply put - I have an Arrowimage.png.4282986699b448d37707288927c5b9b9.pngthat i'm copying to points that are on
1) a line with @N = {0,0,1};
2) a noise deformed grid
The line is pointing in the Z axis before it is passed on to the copy to points sop.
Here is what i'm trying to understand:
I have an point wrangle on the Line and the Grid with the following where @up is set to {0,1,0} and the Angle channel is animated using @Frame;
v@up = chv("up_vector");
vector nCrossUp = normalize(cross(@N,@up)); // Commenting out this line and the one below gives weird rotations
v@up = normalize(cross(nCrossUp,@N));
matrix3 m = maketransform(@N, v@up);
float angleRad = radians(chf("Angle"));
vector axis = normalize(@N);
rotate(m, angleRad, axis);
p@orient = quaternion(m);
This results in the arrows rotating on their @N axis on both the line and grid.
My understanding is that:
We have two approaches when dealing with orientations:
1) Using the cross product of the N and the Up and then crossing the resultant vector again by the @N to get proper @up vectors.
2) We can use the @orient to stabilise the rotation when the template points are deforming.
Furthermore, in the line example above, the Normals of the template points are pointing in the Z-Axis. When I change the normals to be pointing in @N = {0,1,0} it breaks (because the N and the Y are both in the same direction?) How would I go about doing this properly and is there a need to use the cross product approach when using the @orient method?
I have attached the hip file to this post if you want to look at what I've done.
Thanks in advance!
orient_Arrows_v01.hiplc
