Copy Sop... Question
ziggx
I'm sure this is really easy -- but it's got me stumped. I want to instance a tube onto a circle. The only problem is I can't figure out how to get the tubes to point at the center of the circle (so they radiate out like spokes on a wheel).
Been trawling through the help files and the forums but not found anything helpful. Please someone point in the right (radial) direction.
TIA
Ziggx
Hey Ziggx
basically what u can do is append a point sop before ur copy sop, onto the circle, ensure that ur circle is a polygon
then under ur normal entry on the point sop, replace $NX with $TX - $CEX
$NY with $TY - $CEY
$NZ with $TZ - $CEZ
that way, if u turn on the visibility of ur normals, your normals are pointing towards the centre or centroid of ur object.
make sure that ur tube is orientated on the Z axis :-)
hope this help
all the best
brian :blink:
Thanks man -- that did the trick! Thanks again
Ziggx
Hey Ziggx
than under ur normal entry on the point sop, replace $NX with $TX - $CEX
$NY with $TY - $CEY
$NZ with $TZ - $CEZ
hope this help
all the best
brian :blink:
Ziggx
HI! I tried $TX - $CEX $, $TY - $CEY, $TZ - $CEZ I know $CE[X,Y,Z] is for centroid, but what -$CE[X,Y,Z] exactly does in this case? I don't see any change with or without it, what am I missing?
Please answer, someone. Thank you.
Basically its pointing the normals of the geo outwards radially. If you are using this on a sphere then you wouldnt see any changes because the normals of the sphere are already oriented that way.
if you did $CEX - $TX, $CEZ - $TZ, $CEZ - $TZ, it would point all the normals inward towards the centroid of the object.
It is taking the point position of each point ($TX, $TY, $TZ) and subtracting it by the centroid (which by default is at (0,0,0) when you create your geo). Doing this gives your vector, in this case your normal, a direction that points either towards the centroid or away depending on which expression you use.
Hope this makes sense.
