ziggx Posted September 27, 2006 Share Posted September 27, 2006 I'm sure this is really easy -- but it's got me stumped. I want to instance a tube onto a circle. The only problem is I can't figure out how to get the tubes to point at the center of the circle (so they radiate out like spokes on a wheel). Been trawling through the help files and the forums but not found anything helpful. Please someone point in the right (radial) direction. TIA Ziggx Quote Link to comment Share on other sites More sharing options...
aracid Posted September 27, 2006 Share Posted September 27, 2006 Hey Ziggx basically what u can do is append a point sop before ur copy sop, onto the circle, ensure that ur circle is a polygon then under ur normal entry on the point sop, replace $NX with $TX - $CEX $NY with $TY - $CEY $NZ with $TZ - $CEZ that way, if u turn on the visibility of ur normals, your normals are pointing towards the centre or centroid of ur object. make sure that ur tube is orientated on the Z axis :-) hope this help all the best brian Quote Link to comment Share on other sites More sharing options...
ziggx Posted September 28, 2006 Author Share Posted September 28, 2006 Thanks man -- that did the trick! Thanks again Ziggx aracid said: Hey Ziggxbasically what u can do is append a point sop before ur copy sop, onto the circle, ensure that ur circle is a polygon than under ur normal entry on the point sop, replace $NX with $TX - $CEX $NY with $TY - $CEY $NZ with $TZ - $CEZ that way, if u turn on the visibility of ur normals, your normals are pointing towards the centre or centroid of ur object. make sure that ur tube is orientated on the Z axis :-) hope this help all the best brian Quote Link to comment Share on other sites More sharing options...
KOZYX Posted September 30, 2006 Share Posted September 30, 2006 ziggx said: Thanks man -- that did the trick! Thanks againZiggx HI! I tried $TX - $CEX $, $TY - $CEY, $TZ - $CEZ I know $CE[X,Y,Z] is for centroid, but what -$CE[X,Y,Z] exactly does in this case? I don't see any change with or without it, what am I missing? Please answer, someone. Thank you. Quote Link to comment Share on other sites More sharing options...
SpencerL Posted September 30, 2006 Share Posted September 30, 2006 Quote HI! I tried $TX - $CEX $, $TY - $CEY, $TZ - $CEZ I know $CE[X,Y,Z] is for centroid, but what -$CE[X,Y,Z] exactly does in this case? I don't see any change with or without it, what am I missing?Please answer, someone. Thank you. Basically its pointing the normals of the geo outwards radially. If you are using this on a sphere then you wouldnt see any changes because the normals of the sphere are already oriented that way. if you did $CEX - $TX, $CEZ - $TZ, $CEZ - $TZ, it would point all the normals inward towards the centroid of the object. It is taking the point position of each point ($TX, $TY, $TZ) and subtracting it by the centroid (which by default is at (0,0,0) when you create your geo). Doing this gives your vector, in this case your normal, a direction that points either towards the centroid or away depending on which expression you use. Hope this makes sense. Quote Link to comment Share on other sites More sharing options...
