How Do I Run Houdini Or Maya On A Mac?
Allegro
I'm not all that knowledgeable with computer stuff, and really haven't looked at using a Mac before. however, the new Mac Pro looks quite nice. I'm a student in my last year of animation school... and the machine I have at the moment simply isn't going to cut it for the film I intend on doing.
This Mac currently looks like it will have the specs I need... but can it run the software I need? I'm unsure at the moment how much I will be using Houdini, but I most likely will be using Realflow, and will be using Maya, as well as numerous adobe products.
I know that macs are set-up for one button mice... but that obviously isn't going to cut it for 3d applications... so... I'm curious if you can use three button mice on a mac, or if I should look at a different system for what I need.
You can use 3 button mice with the Mac, and Apple's own Mighty Mouse is a 2 button + wheel model. Third party (ex: Logitech) are also available. I suppose any USB mouse would work.
If your going to get a Mac Pro, do yourself a favor and have one with an nVidia card. At least for Houdini work it's better.
Dragos
Also, would you recommend this system for what I need? Or do you have any other ideas for a suitable workstation?
I'll be working on a 1 minute short, which I want to have the quality as high as I can get it. Something on the level of the Digital Domain commercials is what I have in my head at the moment. It's just *not* possible to do any sort of rendering, or particle/dynamics simulation on my present computer that will get me the look I want.
I may have access to a renderfarm for Maya, but any Houdini stuff I choose to do, I'll be left on my own. Additionally, since I have a fair commute, it would be ideal to at least have reasonable rendertimes so that I can get the look I want, before sending it to a renderfarm.
There is no financing option for a Mac Pro in Canada... so... the cost is a turnoff on my present budget. Any suggestions... I should factor cost in. Though that was probably assumed when I mentioned that I'm a student :D
I'm also interested in this answer as I want to buy a new home machine and the new iMac seems pretty nice for casual use at the house. It has an NVidia 7300 card in it too. Has anyone tried this machine with Houdini?
Some unjustified rumour has it that the next generation of Intel-based Macs will have a lot of issues with the introduction of the Intel processor straightened out and should perform better.
seems that bootcamp is not supported on 64bit macs yet. so, you will be out of luck with Houdini.
the performance gain of Maya8 for OSX is around the weak 6-8% compared to Maya 6.5 and 7.0 on the same box. the reason is that the os is still 32 bit and maya is still not compiled as universal binary code. also Maya for osx is really bad choice.
  • 2 weeks later...
  • 2 weeks later...
MAC PRO RUNS HOUDINI AWESOME!!!!!
no problems reported at alll.
-c
Good to hear! I'm still looking for my computer solution, and time is running out.
How do you go about setting it up (having very rarely used a mac in the past, I barely know what I'm getting into)
