set expression by orderMenu value
saca
hi,
the orderManu "Type" has "Asset" and "Sequence" and so on.
and I want to set "directory path" from elements.
but each "Type" bring different expression directory path from some elements.
example,in python
if `chi("Type")` == 0:
    theFilePath = `chs("BaseDir")`/`chs("AssetName")`/`chs("fileName")`;
elif `chi("Type")` == 1:
    theFilePath = `chs("BaseDir")`/`chs("SceneName")`/`chs("CutName")`/`chs("fileName")`;
else:
this expression error occursion.
how to set expression in this case?
thanks
DirctoryMaker_v001.001.hipFetching info...
Edited by saca
hi,
this problem was fixed with this expression bellow.
in Python (theFilePath)
if (`ch("Type")`) == "0":
  return (ch("BaseDir")+"/"+ch("AssetName")+"/"+ch("fileName"))
elif (`ch("Type")`) == "1":
  return (ch("BaseDir")+"/"+ch("SceneName")+"/"+ch("CutName")+"/"+ch("fileName"))
else:
  return (ch("BaseDir"))
DirctoryMaker_v001.002.hip
