How Do You Check To See If A Curve Intersects Itself?
Mr.Ed
Howdo all,
I am still relatively new to all this and have got myself into a bit of a fix.
How do you see if a curve intersects itself and extract the xyz co ordinates at that point?
I started in vex trying to compare the curve with a section of the curve which carves along the length of the curve. If the intersection happens then the angle between the curves should be greater than zero, but I cant seem to get the angle between the curves.
This also seems a long way round if anyone has a better solution. I did try checking for a collision on the loop with itself but if is always colliding with itself
Any help greatly appreciated
Ed
