Rendering In Dops
kingsoz
helloooo
i've done a simulation in DOPs, and its looking just right. However, there are objects I dont' want to render, such as the collision geometry.
I read on the sideFX pdf tutorial for DOPs you use a object merge, and then use the following expression...
/obj/name of dopnet:object name/Geometry
however, this works for the 2 collision geometry objects even though i don't want to pull them in, but it does not work for the RBDpointobject which i have, since i am simulating 100's of objects.
i guess the object merge does not class this operator as geometry object therefor will not let me pull it in?? If so, there must be a simple way to fetch it...
any suggestions would be greatly appreciated!
Cheers
king Soz
Hi, kingsoz
Are you really feeding "object name"?
As default most of object name will be the same as dop operator name, but RBDpointobject will name like,
rbdpointobject1_0
rbdpointobject1_1
Then you need to use something like,
/obj/dopnet1:rbdpointobject1_*/Geometry
You can check object name by Details View or simply middle clicking DOP operator.
cheers,
sho
heheh i only put that on the forum so people know which level i'm trying to access, like i said i can pull 2 of the collision objects in but the one i want won't let me touch it. says that it does not exist!
/obj/rocks_SIMULATE:rocksCopy/Geometry
this one doesn't work, however the following two do...
/obj/rocks_SIMULATE:groundCollision/Geometry
/obj/rocks_SIMULATE:feet*/Geometry
any suggestions?
