Creat RBD pieces along Predefined Cracks on surface.
pb062
Hi all,
I'm looking for a solution for an RBD Problem.
I'm trying to generate cracks on Object with the shortestpath SOP, which than wil be used to animate the growth of the crack and also will be used to cut out the crack deformation on the surface. In the next step I'm trying to create a first fracture along this cracks. If I use the data I get from the shortest path, my Fracture doesn't work because the Geometry is not Fractured completly trough. If I modify my shortestpath to generate my cutting planes, my pieces don't align with the "modeled" cracks at all.
I'm sitting on this problem for more than 2 weeks now made no progress and I'm out of ideas.
attached is my setup and a file which shows the idea worj´king but on a Flat wall not a round 3D Object.
I already check this Form for solutions but I only could find topics where people asked a similar question but got no answer or topics which are old and outdated.
I'm trying to create something simular to the Topic below.
If someone could find time to help me it would be very much appriciated.
cheers
Cracks_with_Fracture_help_02.hipnc
dm_wallCrack.hip
