anicg Posted July 17, 2020 Share Posted July 17, 2020 (edited) For each existing shop_materialpath (there are a lot of them): - create a group, with the same name as the shop_materialpath - create and assign a material with the same name as the shop_materialpath Edited July 23, 2020 by anicg Quote Link to comment Share on other sites More sharing options...
sadhu Posted July 18, 2020 Share Posted July 18, 2020 Check this file group_material.hipnc Quote Link to comment Share on other sites More sharing options...
anicg Posted July 18, 2020 Author Share Posted July 18, 2020 (edited) 10 hours ago, sadhu said: Check this file group_material.hipnc I'm a bit lost here, I meant for each existing shop_materialpath, I do not need to create any shop_materialpath, I need to create groups and materials. I have a 3D model pack that has some 30 shop_materialpaths, I just need each one of them to become a group and have a material in the mat context with the same name. the shop_materialpath is a starting point, it's an input that we already have. Edited July 18, 2020 by anicg Quote Link to comment Share on other sites More sharing options...
eimk Posted July 18, 2020 Share Posted July 18, 2020 not entirely sure what youre wanting but hopefully this helps: shop_materialpath.hipnc shop_materialpath_py.txt assuming all of your geometry has a shop_materialpath attribute, the wrangle will create a group for each then if you run the code in the source editor (if its not already there paste in the txt file) it will create a new material in /mat for each group, and add each group and corresponding shop_materialpath to the material node Quote Link to comment Share on other sites More sharing options...
