HappehLemons Posted July 30, 2020 Share Posted July 30, 2020 (edited) I've got an emitter, and within the autodop networks flip solver I have rest enabled. I'm using an attribute wrangle with the expression v@uv = @rest;, and getting weird results with it. Here's a frame: I've seen lots of examples of people able to get awesome UVs mapped to their emitters using rest like: Why are mine so far off? Edited July 31, 2020 by HappehLemons Quote Link to comment Share on other sites More sharing options...
bunker Posted August 1, 2020 Share Posted August 1, 2020 on the ParticleFluidSurface/Surfacing/ Ouput , try Attribute radius: 10, and attribute Samples: 200. The values depend on how many particles you have. Quote Link to comment Share on other sites More sharing options...
ziconic Posted August 9, 2020 Share Posted August 9, 2020 Well if your fluid shape doesn't change drastically after the rest attribute is set, you'll get better results. For example, if you change the emitter to a tube instead of a sphere, the uvs will look better as the fluid flows downward since it's a better match for the fluid shape before it hits the ground. You should also look into reducing Frames Between Reset on the FLIP Solver so that you aren't trying to smear out your rest position over a surface that looks very different from what you started out with. Quote Link to comment Share on other sites More sharing options...
HappehLemons Posted August 14, 2020 Author Share Posted August 14, 2020 Nice! Thanks for the tips guys. There's still some tinkering to be done here but I'm already getting a MUCH better result with just these few suggestions. Quote Link to comment Share on other sites More sharing options...
HappehLemons Posted August 14, 2020 Author Share Posted August 14, 2020 My latest hurdle is getting the texture to warp around my emitter properly. I have my rest only on frame 0, because I don't want flicker or changers later but my frame 0 "snapshot" could use some work. Any advice on this? Quote Link to comment Share on other sites More sharing options...
ziconic Posted August 16, 2020 Share Posted August 16, 2020 Well you'll probably want to use one of the UV sops like UV Project to convert your rest position to uv, rather than setting @uv to @rest directly. To do so, you'll have to save @P to some custom attribute, copy @rest to @P, use your UV sop of choice to generate your uvs, then restore @P from your custom attribute. Quote Link to comment Share on other sites More sharing options...
