Baking animation to curve from expression
I have an imported character animation from abc. I would like to offset the animation to do FX. I have a centroid as that's all i need. I would like to bake that out as an animated curve so I can manually scale the inverse curve to my liking.
I tried using a point() expression to get the transform channels into a transform node. I then tried baking the channels view the baking menu, but it crashed houdini. I'm guessing there's a proper way of doing this........
I heard people were using chops, but also that it was meant for exporting to unity or something? I don't need to export the animation curves to another software. I literally just need animation curves to edit in the animation curve editor.
Thanks!
here is a simple example with Python, I attached an example:
parm = hou.parm('/obj/geo1/sphere1/ty')
# store all values in list
values=[]
for i in range(100):
  val = parm.evalAsFloatAtFrame(i)
  values.append(val)
# remove parm expression
parm.deleteAllKeyFrames()
# set values from list to keyframes
  myKey = hou.Keyframe()
  myKey.setFrame(i)
  myKey.setValue(values[i])
  parm.setKeyframe(myKey)
bake_keyframes.hipnc
  • Like 2
Awesome thanks Julien!
Just wanted to throw this out there in case anyone else needs this script:
1)  the 'F' in parm.deleteAllKeyframes() is lower case.
2)  if the shot does not start at frame 1, but instead 1001, an offset value will need to be calculated for  myKey.setValue(values[j]) where j is i-1001 (for example)
It took me a bit longer than it should've to realize values was trying to pull a value from an index that didn't exist (1001)
Thanks Wilson, I noticed the lowercase F afterwards and couldn't edit the code unfortunately.
here is a improved code with start/end frame/increment - yes, you can use decimal frames too!
import numpy as np
startframe = 1001
endframe = 1100
increment = 1
values=[]
for i in np.arange(startframe, endframe, increment):
  frame = round(i*100)/100.0
  value = parm.evalAsFloatAtFrame(frame)
  mydict = {'frame':frame , 'value':value}
  values.append(mydict)
for i in values:
  myKey.setFrame(i['frame'])
  myKey.setValue(i['value'])
