MadMax50 Posted August 5, 2020 Share Posted August 5, 2020 Hello, I am trying to understand primuv a little better . All I would like to do is get my particles sticking to the surface of the character in dops. I am writing this in a pop wrangle: vector primuv; int prim; v@sample=primuv(1, "P", prim, primuv); v@P = v@sample; For some reason, it's only returning the position of 1 point. Why isn't it returning the position of all the points ? I will attach my file for anyone that wants to take a look Thank you primuv_understanding.hipnc Quote Link to comment Share on other sites More sharing options...
toadstorm Posted August 5, 2020 Share Posted August 5, 2020 Well, you're not really defining what "prim" and "primuv" are. You're initializing them as variables, but you have to actually set them to something to be useful. Primuv() usually works alongside xyzdist()... xyzdist can fetch the "prim" and "primuv" values from the nearest point on the surface, and then you can pass those values along to primuv. It's a little confusing because xyzdist() has some quirks in its arguments. If you look at the docs for xyzdist(), there's a little "&" following the prim and primuv arguments. This means that even though xyzdist officially returns a float (the distance to the surface from your lookup position), it can also write to those & arguments. So the full code would look something a little more like this: int prim; vector primuv; float dist = xyzdist(1, @P, prim, primuv); // this actually WRITES to prim and primuv! vector sample = primuv(1, "P", prim, primuv); // this is fetching P from the prim and primuv coords supplied v@P = sample; 1 Quote Link to comment Share on other sites More sharing options...
MadMax50 Posted August 6, 2020 Author Share Posted August 6, 2020 @toadstorm Thanks for the reply toadstorm. That makes a lot more sense. I wanted to do some examples only using the primuv so that I have a solid understanding of this function before I use it in conjunction with xyzdist. That being said, can I throw another problem at you? I'm using the primuv function inside of a for loop and my goal is to set a point in the middle of each primitive of a grid. I have 20 points and im feeding it into a wrangle like this: vector uv = set(0.5, 0.5, 0); for(int i=0; i<20; i++){ @P=primuv(1,"P", i ,uv); } However, the points only move towards 1 primitive. I thought that using the iteration number as the primnum would work but it seems like i'm missing something here Thanks for the help primuv_understanding2.hipnc Quote Link to comment Share on other sites More sharing options...
toadstorm Posted August 6, 2020 Share Posted August 6, 2020 This is because, I assume, you're doing this in a point wrangle. The problem is that point wrangles are inherently a for/each loop, looping over each point. This means that every one of your points is looping over all 20 primitives, then stopping on the 20th primitive, simultaneously. Instead, assuming you have 20 points and 20 prims: vector uv = set(0.5, 0.5, 0); @P = primuv(1, "P", @elemnum, uv); @elemnum, @ptnum, @primnum, etc. are automatic attributes inside the wrangle that tell you which point, prim, or whatever you're currently iterating on. 1 Quote Link to comment Share on other sites More sharing options...
MadMax50 Posted August 6, 2020 Author Share Posted August 6, 2020 @toadstorm very interesting. Thank you. makes perfect sense Quote Link to comment Share on other sites More sharing options...
