Daniel16_16 Posted August 23, 2020 Share Posted August 23, 2020 Hey all I have a strange problem with my pyro sim. The flames are cutting of in the Render view tab. (like in the picture)... What is caussing this? I have press more times before that the "smokeless flame" shelftool and everything was fine...but since one moment something is strange there... :/ Help would be very nice.. Quote Link to comment Share on other sites More sharing options...
Eckxter Posted August 24, 2020 Share Posted August 24, 2020 My guess is the value mapping in your shader is not the same as the one in your visualizer in DOPs/SOPs. Try to troubleshoot by checking what the min and max values are on the visualizer in DOPs and copy those values over to your shader. Making sure that it's using the same fields as well. Or, where you import the volumes in SOPs, plug them into a Volume Visualization SOP and check whe range of values you need for what you want. Once you have something you like, use those values for the corresponding fields in your shader and work forward from there. Or, you could share your scene and we could have quick look. Quote Link to comment Share on other sites More sharing options...
Daniel16_16 Posted August 24, 2020 Author Share Posted August 24, 2020 Here is the file Starship test rocket launch.hipnc Quote Link to comment Share on other sites More sharing options...
Daniel16_16 Posted August 24, 2020 Author Share Posted August 24, 2020 and here is the 3D Model for this file BFR Original.obj Quote Link to comment Share on other sites More sharing options...
Eckxter Posted August 24, 2020 Share Posted August 24, 2020 Opening your file, siming to frame 25 and hitting enter gives me this. In the viewport: And this in the render view: I'm not getting any cutoff. Quote Link to comment Share on other sites More sharing options...
Daniel16_16 Posted August 24, 2020 Author Share Posted August 24, 2020 you should try some other perspective try from a bit far away and look from down... Quote Link to comment Share on other sites More sharing options...
Eckxter Posted August 25, 2020 Share Posted August 25, 2020 I still don't get any cutoff. No matter how far/low I go. Are you sure you've given the exact same scene? Maybe it has got something to do with your hardware? Reaching memory limit or something along those lines. Quote Link to comment Share on other sites More sharing options...
