ChazS Posted August 24, 2020 Share Posted August 24, 2020 (edited) I've followed the directions on the help page (https://www.sidefx.com/docs/houdini/nodes/cop2/cornerramp.html) but still can't select more than a single point on a ramp within the parameter window. Per the doc, holding down 'alt' doesn't allow me to click and drag over multiple points. I've tried multiple combos of Kb+mouse button combos, which includes but limited to starting the selection inside and outside of the ramp itself, Ctrl+left, middle & right buttons, Ctrl+Alt, Ctrl+Shift, Alt+Shift, Ctrl+Alt+Shift to no avail. Ctrl+selecting individual points isn't working either. If you have a moment, would you mind giving it a try and letting me know if you're successful or not? If you get it to work, I'd love to know what you're doing... puh-leazz? Many thanks Edited August 25, 2020 by ChazS Updating status Quote Link to comment Share on other sites More sharing options...
eikonoklastes Posted August 25, 2020 Share Posted August 25, 2020 (edited) That documentation is for selecting gradient points in the Composite View, when working in a COP network. Is that what you're after, or are you referring to a ramp parameter in SOPs? If it's the latter, you can Ctrl+click to select non-contiguous points, or Shift+click to select a range in sequence. The visual indicator for the selection is pretty poor, but it does work. Edited August 25, 2020 by eikonoklastes 1 Quote Link to comment Share on other sites More sharing options...
ChazS Posted August 25, 2020 Author Share Posted August 25, 2020 @eikonoklastes :: Thanks! They are points in a Redshift volume. Pardon my naivité but that's a SOP, right (since it affects the surface)? In any case [SOLVED]. I had also missed the helper with all the relevant combos since I was moving around too fast. Many thanks! Quote Link to comment Share on other sites More sharing options...
