Jimmy_Fan Posted August 25, 2020 Share Posted August 25, 2020 Like I was trying to generate some cloud by copy to point with one cloud input. According to the help file, packed geometry will certainly reduced lots of render resources because it will ignore the geo outside of the frame, but when it comes to volume, once I checked Packed Instance, all the volume disappeared in render buffer(redshift), there should be something wrong with copy to point ? Or do I have to manually output density attribute ? BTW, is there effective way to reduce volume noise in redshift? Thx ! Quote Link to comment Share on other sites More sharing options...
