callandekeijzer Posted August 25, 2020 Share Posted August 25, 2020 (edited) Hi I am trying to follow Ari's tutorial https://vimeo.com/323291527 for generating a side by side montage of some wedged Pyro sim, that i'm trying to test out. My TOP network seems to work fine except the final node: ffmpegencodevideo. I am not really sure how to set the correct path on windows, as Ari's version is for MAC, and have tried removing the C:, .exe and also using forward and backslashes. Do I even need to set the environment file to look at the FFMPEG? Quite confused on how to set this up correctly. Edited August 25, 2020 by callandekeijzer Quote Link to comment Share on other sites More sharing options...
HappehLemons Posted August 25, 2020 Share Posted August 25, 2020 (edited) Here's a screenshot of mine if it helps, which works. Also I remember when I installed Image Magick for ffmpeg there were a few options. If I didn't do the full install, and select everything, it wouldn't work in Houdini for some reason. Here's the tutorial i followed as well Edited August 25, 2020 by HappehLemons Quote Link to comment Share on other sites More sharing options...
callandekeijzer Posted August 26, 2020 Author Share Posted August 26, 2020 @HappehLemons Yeah i saw that one too, i also tried using the one built in to imagemagick or just downloading ffmpeg itself, not really sure what the difference is but with both it still ended up in the encodevideo TOP not working. is there anything special you filled in the node, to get it working as intended? Quote Link to comment Share on other sites More sharing options...
