Phelme Posted August 28, 2020 Share Posted August 28, 2020 Hi, I have a strange problem with the latest Houdini remesh node. I am busy preparing collision geometry by first shrinkwrapping it and then taking it through a forloop where I have a remesh leading into a ray sop set to minimum distance and then after the loop I have a polyreduce. Just to visualize the volume collision geo before taking it into my dopnet I placed a VDBfrompolygons node. When I use an earlier version of the remesh node I good a really good result which works well. However since repeating this procedure with the new remesh node I get a completely different result and a very poor collision geometry outcome. The setup is exactly the same, the only difference is the new remesh node. If I switch it out for the older version then I get a good result again. Does anyone know what could be causing this? I cannot see what can be causing this issue in the latest remesh node and I cant seem to get a good result when using it. Quote Link to comment Share on other sites More sharing options...
