Vellum Random colors
davidyannick
you can use "Vellum Patch Name" attribute in vellumsource node to identify each iteration, then out of the dopnet (after vellumpostprocess) use a color SOP set to Random From Attribute: patchname. Patchname is a point attribute.
Is that the result you wanted?
10 hours ago, curv.u said:
thanks but no, Ii'd like each ball to have a different color
oh yes, of course you should make patchname as unique identifier, so in vellumsource node add $OS_$F for example. The result will be "node_name"_"frame_number" ( = vellumsource_1 if you're on first frame). Check on the Spreadsheet to see the newly created names: your goal should be to have a different name for each frame a ball is emitted, that gives you the dissimilarity useful for the random function.
