Subnet referencing issue
Jestic
Hopefully someone could help me with an issue i'm having, it's probably quite simple and i'm just not seeing it. I come from a 3ds max background so this is all a bit new to me, my apologies if I use any wrong terminology, hopefully it's clear enough.
I have a switch sop with the following expression:
Said switch sop is placed inside the following subnet: (CliffPieces_Gen_01)
Now you might already see the issue; right now it's only referencing the foreach metadata inside CliffWall_Gen_01, but not CliffWall_Gen_02 (there will be a lot more, right now it's just 2 as a proof of concept)
How can I make it so the switch sop hooks into each foreach metadata, in each subnet? (without having to make multiple copies of the switch sop)
Contents of the IHL CliffWall Gen 01 HDA, in case you need more context:
you can pack individual inputs of your switch SOP and merge into a single geo
and use Copy SOP with variant attribute per point which will pick the packed prim based on the attribute value, no foreach necessary
cant post files at the moment, but following posts may have some relevant info
https://forums.odforce.net/topic/45644-how-to-separate-geo-from-a-single-node/?do=findComment&comment=214038
https://forums.odforce.net/topic/45444-copy-to-points-variant-issue/?do=findComment&comment=213201
  • Thanks 1
The first link did the trick, thanks!
