TimurH Posted September 8, 2020 Share Posted September 8, 2020 Hi! If we create a pyro by Wispy Smoke shelf tool and then apply Distribute Container shelf tool, it creates: But it does not work! Smoke can`t pass slice border. But! It works after a small adjustment: So after shelf script, i should not merge distribute_pyro node with the source, but should connect it to the solver Velocity Update input. I am doing something wrong? Or it is shelf tool error? How you distribute pyro on several machines (slices)? Quote Link to comment Share on other sites More sharing options...
