Gayane Posted September 11, 2020 Share Posted September 11, 2020 (edited) Hello everyone! What are the possible answers for the low quality sim? Before volumerasterizeattributes I had 60mil particles, after that the resolution got worse and I see substeps in the viewport. Thank you so much! nebula_16.hipnc Edited September 11, 2020 by Gayane Quote Link to comment Share on other sites More sharing options...
Neronie Posted September 11, 2020 Share Posted September 11, 2020 It's the viewport's default volume resolution limit. Go to the Display settings (press D while hovering over the scene panel) and either disable or increase the limit on the 3D Texture resolution tab: Quote Link to comment Share on other sites More sharing options...
Gayane Posted September 11, 2020 Author Share Posted September 11, 2020 53 minutes ago, Neronie said: It's the viewport's default volume resolution limit. Go to the Display settings (press D while hovering over the scene panel) and either disable or increase the limit on the 3D Texture resolution tab: Thank you so much!! Everything works. Quote Link to comment Share on other sites More sharing options...
