TOP/PDG Python processor fetch files
mik74
Hello,
I would like to fetch files using python into work items.
I have an array of file paths and I want to create a work item per file basically to process them.
Same way as the “filepattern” top but with python processor.
I can not find the python way to do that.
Thank you guys
Hi Mikel,
I believe this question should be posted in the Scripting Forum
But here's how I would do it
Inside a Python Processor,
from os import listdir
path = r"C:\someFolder"
allFiles = listdir(path)
for file in allFiles:
	newItem = item_holder.addWorkItem()
	newItem.setStringAttrib("file", file)
	newItem.setStringAttrib("path", path + "\\" + file)
Basically, using this documentation page, you can see how to add a work item
This tells you that the resulting object is → pdg.WorkItem
If you follow it to its documentation page, there you can see how to add an attribute to said work item
Edited by Alain2131
