Bill Mill Posted September 20, 2020 Share Posted September 20, 2020 I'm having a hard time getting the "Hair Generate" node of my geometry to be projected in its UV when using the "Bake Texture" node. The error presented is that there was no normals and UV map for OUT_GROOM when I tried with the settings of the image (geometry and hair are inside subnet1). I already tried on a "Geometry" node to use the "Object Merge" to bring the geometry and the hair together, and this works so that at least I can project something on the UV. Still, that way I can't apply a material like the "Hair Shader" to the "Object Merge" of the hair, the hair always stays white. No surface base color is showing. Quote Link to comment Share on other sites More sharing options...
