v.frerichs Posted September 28, 2020 Share Posted September 28, 2020 Hi, Currently, I'm working on a small sim where a character gradually fills up with water. I'm trying to have more control over the emission rate, when using the emit particle fluid shelf tool. It seems like the "Scale Source Volume" slider on the Volume Source DOP has been removed. Normally, it would be found below the "Activation" slider. I attached a screenshot of the parameter view of said node. So, my question is as follows: where can I find a similar parameter in Houdini 18? Best regards Quote Link to comment Share on other sites More sharing options...
