Set Style Sheet of a Houdini Button
gemini
  Can it be done somehow to set style sheet of a Houdini button ?
Thanks!
Sz
from PySide2 import QtWidgets
class MainWindow(QtWidgets.QMainWindow):
    def __init__(self, parent=None):
        super(MainWindow, self).__init__(parent)
        self.construct_ui()
    def construct_ui(self):
        self.setStyleSheet(hou.qt.styleSheet())
        self.setProperty("houdiniStyle", True)
        self.setWindowTitle('PySide2 Test')
        # main widget
        main_widget = QtWidgets.QWidget(self)
        self.setCentralWidget(main_widget)
        # layout initialize
        g_layout = QtWidgets.QVBoxLayout()
        layout = QtWidgets.QFormLayout()
        main_widget.setLayout(g_layout)
        # Add Widgets
        self.parm = QtWidgets.QSpinBox()
        self.parm.setValue(30)
        self.parm2 = QtWidgets.QDoubleSpinBox()
        self.parm2.setValue(30)
        layout.addRow('Parameter', self.parm)
        layout.addRow('Parameter', self.parm2)
        self.exec_btn = QtWidgets.QPushButton('Execute')
        self.exec_btn.setStyleSheet("background-color: darkorange")
        self.exec_btn.setFlat( False)
        # global layout setting
        g_layout.addLayout(layout)
        g_layout.addWidget(self.exec_btn)
