Blackagate Posted October 12, 2020 Share Posted October 12, 2020 Hi all, I have a specific problem. In Houdini 16.5 I had an asset where I used Connect Adjacent Pieces. When I tried to open this asset in Houdini 17.5, the lines behavior was totally different. A detailed analysis showed that the problem is inside of a VEX-code and pcfind_radius funktion that works differently now. I didn't find any mentions of it in the documentation. Does anybody now, what exactly was changed, and how therefore I could return the previous behavior back? Here I attach two screenshots. H16.5: H17.5: And then the example file with a test geo points. Thanks a lot! test_pcfind.zip Quote Link to comment Share on other sites More sharing options...
