(SOLVED)Viewer States install in specific context
Hi guys so i've been using viewer states in Houdini 17.5 and they're great but I was wondering if there is a way to have the OTL not install the viewer states depending on context. My current predicament is when a job is sent to Tractor the node errors out the job(even if it's not being used). My guess this is due to tractor using hython? Where there is no interface but the OTL is still trying to install and getting the "Not available in this context" error.
SOLVED: Solution was to make the viewer state check if there was a ui using hou.isUIAvailable() before installing.
Edited by shadowst17
