davidyannick Posted October 19, 2020 Share Posted October 19, 2020 I'm trying tto convert a python scipt to vex, is there a VEX equivalent to rfind (python) ? node = hou.pwd() geo = node.geometry() for prim in geo.prims(): path=prim.attribValue("name") newpath=path[:path.rfind("/")] prim.setAttribValue("name",newpath) Thanks Quote Link to comment Share on other sites More sharing options...
Alain2131 Posted October 19, 2020 Share Posted October 19, 2020 Bonjour David, A quick Google Search gives this as the first result → find This gives the first occurrence instead of the last one. To find the last one, I would invert the string temporarily. Although it looks like you are trying to split a path to get the name of the file (or the last folder) There is the splitpath function that does just that. Hope that helps ! Quote Link to comment Share on other sites More sharing options...
davidyannick Posted October 20, 2020 Author Share Posted October 20, 2020 17 hours ago, Alain2131 said: Bonjour David, A quick Google Search gives this as the first result → find This gives the first occurrence instead of the last one. To find the last one, I would invert the string temporarily. Although it looks like you are trying to split a path to get the name of the file (or the last folder) There is the splitpath function that does just that. Hope that helps ! thanks it helps me a lot, I'm a complet noob in Python sorry Quote Link to comment Share on other sites More sharing options...
