Invalid node type name "heightfield_file"
cgdougm
ISSUE: Trying to create a "HeightField File" SOP node using python.
STEP #1: Make code that Houdini thinks is correct
I create a hip file that has just "/obj/geo/height", a node which is of type "Heightfield File."
I make code for the node using
hou.node("/obj/geo/height").asCode()
The node type in the generated code is "heightfield_file" as you would expect.
STEP #2: Try to recreate the original file
Then, using the generated code as a guide, simplifying it, I run it and get this error:
hou.OperationFailed: The attempted operation failed.
The code I ran (with vanilla python rather then hython, because, that's epic) was:
import sys, os
sys.path.append(
    os.environ['HFS'] + "/houdini/python%d.%dlibs" % sys.version_info[:2]
import hou
hou.hipFile.clear()
hou_parent = hou.node('/obj')
hou_node = hou_parent.createNode("heightfield_file")
...and yes, I tried 'hython" too after removing the sys.path trick.
Any hints or ideas?
TIA
