ManHatTan Posted October 21, 2020 Share Posted October 21, 2020 Hi. Newbie question again. I'm exporting a lot of my 3ds max assets (grass patches etc) to Houdini and I need them for scattering, which means I need to be able to pick individual objects. I'm exporting using alembic and each object inside the alembic have a group, but I can't figure out how to separate them. I found posts about writing a python script that separates each group into geo, but I'd prefer a less manual way, if there is one, since the contents of the alembic might change. What's the best way to do this? Thank you. Quote Link to comment Share on other sites More sharing options...
davpe Posted October 21, 2020 Share Posted October 21, 2020 (edited) hi, if you make an attribute from groups and export as alembic you should get an object per attribute value (typicallyhaven't its a @path attribute) when imported to a 3d software. note that attribute needs to be a primitive string data type. read the docs for more info: https://www.sidefx.com/docs/houdini/io/alembic.html cheers, D. edit: sorry I haven't been reading your post properly - if you want to import alembic groups as objects into Houdini, just use alembic archive object instead of alembic SOP. edit 2: but for scattering. it's actually much better to have your objects as a single geo. you can use packed geometry that basically splits the object into individual elemets by groups, an attribute, or connectivity. Edited October 21, 2020 by davpe Quote Link to comment Share on other sites More sharing options...
ManHatTan Posted October 21, 2020 Author Share Posted October 21, 2020 17 minutes ago, davpe said: hi, if you make an attribute from groups and export as alembic you should get an object per attribute value (typicallyhaven't its a @path attribute) when imported to a 3d software. note that attribute needs to be a primitive string data type. read the docs for more info: https://www.sidefx.com/docs/houdini/io/alembic.html cheers, D. edit: sorry I haven't been reading your post properly - if you want to import alembic groups as objects into Houdini, just use alembic archive object instead of alembic SOP. edit 2: but for scattering. it's actually much better to have your objects as a single geo. you can use packed geometry that basically splits the object into individual elemets by groups, an attribute, or connectivity. Hi. Thanks for answering. I didn't know there was an alembic archive node, I'll check it out when I'm in front of Houdini. About your second answer: Would you happen to have an example of how that works? How do I pick the individual elements to be used for scattering? I have the scatter set up, I just need the objects to feed it. Thanks. Quote Link to comment Share on other sites More sharing options...
davpe Posted October 21, 2020 Share Posted October 21, 2020 (edited) yeah, alembic archive just loads the whole scene hierarchy as you see it in 3ds max or whatever software you use. it can be useful for rendering but it's not too convenient to work with with Alembic SOP, objects load as packed primitives by default - 3 objects in 3ds max are loaded as 3 packed prims, but are all part of the same object if it makes sense. alembic_scatter.hiplc in the example it works as following: 1) in the stream on the right hand side, attribute_randomize SOP randomly generates an attribute called @instance, with values between 0 and 2 (this is for 3 alembic objects numbered from 0 to 2) 2) in the stream on the left hand side, there is an alembic SOP containing 3 different objects. delete SOP wired after that reads the @instance attribute value for each point, and all the primitives not matching that number are removed. only the selected object makes it through. 3) after that the copy_to_points SOP inside of the loop makes the actual instancing. there are many ways how to handle this, this is one. also check out his video - little bit different workflow but it can help you understand better how things work: Edited October 22, 2020 by davpe Quote Link to comment Share on other sites More sharing options...
ManHatTan Posted October 22, 2020 Author Share Posted October 22, 2020 10 hours ago, davpe said: yeah, alembic archive just loads the whole scene hierarchy as you see it in 3ds max or whatever software you use. it can be useful for rendering but it's not too convenient to work with with Alembic SOP, objects load as packed primitives by default - 3 objects in 3ds max are loaded as 3 packed prims, but are all part of the same object if it makes sense. in the example it works as following: 1) in the stream on the right hand side, attribute_randomize SOP randomly generates an attribute called @instance, with values between 0 and 2 (this is for 3 alembic objects numbered from 0 to 2) 2) in the stream on the left hand side, there is an alembic SOP containing 3 different objects. delete SOP wired after that reads the @instance attribute value for each point, and all the primitives not matching that number are removed. only the selected object makes it through. 3) after that the copy_to_points SOP inside of the loop makes the actual instancing. there are many ways how to handle this, this is one. also check out his video - little bit different workflow but it can help you understand better how things work: https://vimeo.com/manage/338056551/general alembic_scatter.hiplc Thank you very much! That video had lots of good info (the link points to your vimeo dashboard, by the way), I'll try it out. This will work perfectly for what I need now, but for future reference: if I want to single out specific objects from an alembic file (each object has a corresponding group), how would I do that? Quote Link to comment Share on other sites More sharing options...
davpe Posted October 22, 2020 Share Posted October 22, 2020 (edited) if you need to separate groups into it's own nodes then you've got basically three options I know about: 1) manually with delete SOP nodes (in each one select a group and delete non-selected) 2) Python script that can make it automatically (you can put it in the shelf and have one-click solution) 3) Alembic Archive instead of Alembic SOP - that will give you the same object hierarchy as in other apps, if that's what you want Edited October 22, 2020 by davpe Quote Link to comment Share on other sites More sharing options...
ManHatTan Posted October 22, 2020 Author Share Posted October 22, 2020 1 hour ago, davpe said: if you need to separate groups into it's own nodes then you've got basically three options I know about: 1) manually with delete SOP nodes (in each one select a group and delete non-selected) 2) Python script that can make it automatically (you can put it in the shelf and have one-click solution) 3) Alembic Archive instead of Alembic SOP - that will give you the same object hierarchy as in other apps, if that's what you want Sounds like alembic archives might be the way to go if I get there. Or a python script, once I learn Houdini python. Thanks again. Quote Link to comment Share on other sites More sharing options...
davpe Posted October 22, 2020 Share Posted October 22, 2020 this should help with Python: https://vfxbrain.wordpress.com/2016/03/15/python-in-houdini/ Quote Link to comment Share on other sites More sharing options...
ManHatTan Posted October 22, 2020 Author Share Posted October 22, 2020 48 minutes ago, davpe said: this should help with Python: https://vfxbrain.wordpress.com/2016/03/15/python-in-houdini/ Perfect, thank you. Quote Link to comment Share on other sites More sharing options...
