Grouping with multiple BBOXs
You can change the group node under "Bounding Type" to "Bounding Object" - then it will take the geometry from the second input to group your points. If you create a box and plug that box into the second input you basically have recreated the type "Bounding Box", just with more options. So you can for example create many boxes, merge them and then plug this merge-node into your second input on the group node - like many bounding boxes.
