rejschaap Posted November 13, 2006 Share Posted November 13, 2006 Right now when I want to create an animation curve quickly I do the following: - create a Fetch CHOP - add a spare channel to it - add keyframes with corresponding values to the channel - import the channel in the Fetch CHOP However, I think it would very handy if there was something like a Bezier CHOP. I've installed the HDK myself and have been experimenting with it for a bit. So far I've created a CHOP that allows the user to create a channel that uses cubic interpolation on a fixed amount of points that can be adjusted in the viewer. I later found out that this is really a subset of what the Pulse CHOP is already offering. It was a good exercise nonetheless. What I'm thinking about is a Bezier CHOP where you could just draw a Bezier curve directly in the viewer. I'm not sure if the CHOP viewer controls would allow for something like this, the controls seem a bit more limited than the SOP controls. I'm wondering if anyone else thinks that such a CHOP would be useful. And maybe someone has ideas about how to implement this? Quote Link to comment Share on other sites More sharing options...
edward Posted November 13, 2006 Share Posted November 13, 2006 Have you checked out the Spline CHOP? Quote Link to comment Share on other sites More sharing options...
sibarrick Posted November 14, 2006 Share Posted November 14, 2006 Or if you just want a generator chop to make a keyframed curve how about doing it in an asset like this curveChop.zip Just keyframe the chan parameter, then you can use any animation curve types you like. Quote Link to comment Share on other sites More sharing options...
rejschaap Posted November 16, 2006 Author Share Posted November 16, 2006 Yeah, I'm looking for a generator CHOP. Interesting asset there sibarrick, it saves a couple of steps to create a simple channel. I will see if I can do something with that and combine it with the Spline CHOP so I don't have to create keyframes. Thanks for the suggestions! Quote Link to comment Share on other sites More sharing options...
