MADjestic Posted November 15, 2006 Share Posted November 15, 2006 hi, I think everyone has seen this "Disable when" parameter in many VOP nodes - obviously what it does is similar to #pragma disable A B 0 VEX stuff. However I had hard time trying to find out what format this parameter expects to work (to disable itself when another parameter has some value) , Houdini Help was not very helpful either. Does anybody have experience with this? Can you give an example of an expression that should be entered into this 'Disable when' parameter? Thanks. Quote Link to comment Share on other sites More sharing options...
Jason Posted November 15, 2006 Share Posted November 15, 2006 Here is an example: { map "" } or for multiple conditions { use_map 1 } { mode "zdepth" } I hope this helps, Jason Quote Link to comment Share on other sites More sharing options...
