Launch houdini from command prompt
Hello,
When I use linux, I always launch houdini from terminal. Anytime I need to print data or view something that normally goes to the console window (like how windows 10 outputs stuff) it just goes to terminal window in which I launched houdini. Obviously I can launch houdini in the command prompt on windows by navigating to the folder and typing start hindi.exe, but how do I get it to also output to the command prompt instead of the console window (if possible)?
Thanks
