(Solved)FLIP: cutoff low density areas Help
gangland
Hello guys, i trying to delete areas where has low density of particles.
i saw a tips on this page: http://www.cgchannel.com/2020/03/10-expert-tips-for-better-houdini-flip-fluid-simulations/
on hint 5, he wrangle an array using a pcfind then apply to pscale.
ive done same here, even copy to wrangle code into a basic setup here, but still not working.
maybe it has something with the content of the page that isnt working? i dont know.
thanks in advance
ps: i attaching an simple .hip file
flip_density_.hip
Edited by gangland
Hi Gabriel, I didn't check whole file, but you set low "Max Pts = 0.636" here:
/obj/import_flip/pointwrangle1
That argument should be two or more (the current point itself also gets returned as a first point)
See here in the docs:
https://www.sidefx.com/docs/houdini/vex/functions/pcfind.html
Only the maxpoints closest points within the given radius will be returned.
Edited by ikoon
Jiri, you was absolutely correct, that argument wasnt returning any neighbor, i feel totally fooled by that vex expression lol.
thanks
  • gangland changed the title to (Solved)FLIP: cutoff low density areas Help
