Wires & constraint network - repelling
anago
Hi! I'm trying to build a simple constraint network with two sets of wires (pink and black). Each set of lines should be connected within itself, and should be repelled to the other set.
The wires simulate ok and the constraint of WireGlue works to keep them together. The problem is when integrating the WirePush (Bullet soft constraint, restlength 1.5), it all gets connected weirdly. I have tried it with Spring constraint and it's the same, it doesn't push the wires at all just gets jumbled. I can't seem to figure out what's wrong as I have followed examples of merging multiple constraints  by creating and assigning @constraint_name. Any help would be super appreciated!
network_constraints_question.hipnc
