demoan666 Posted January 2, 2021 Share Posted January 2, 2021 I have a simple scene with mixamo animation applied to a character, and added some point level animations (jiggle) however when i eventually try to export it with ROP alembic output, it crashes (the node is able to export any other regular animations without any problem though). The only node that seems to be able to export from kineFX is the ROP FBX character output (which doesn't export Point level animations) is this happening with everyone? does any one know a work around? thanks in advance D Quote Link to comment Share on other sites More sharing options...
demoan666 Posted January 2, 2021 Author Share Posted January 2, 2021 [SOLVED] Ok something is wrong with the installation on this PC, it worked fine on another PC. (dunno whats causing the crash tho!) Quote Link to comment Share on other sites More sharing options...
