Gigglebooster Posted January 4, 2021 Share Posted January 4, 2021 Hi. Is there a max render resolution for Houdini Indie? I've been looking for awhile and haven't found one. However, if I render at a larger resolution than 6000x4000 Houdini crashes. Doesn't matter if I have anything in the scene or a full scene so I feel like it's not a VRAM issue. Can't tell if this is a limitation with Houdini or an issue with Redshift, thx. Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted January 4, 2021 Share Posted January 4, 2021 This shouldn't be a Houdini licensing issue, you can see the Indie limitations here: https://www.sidefx.com/products/compare/ I'd recommend trying to look at the Redshift logs to see if it gives any explanation of the crash. Quote Link to comment Share on other sites More sharing options...
