hello guys,
does someone succeeded in using correctly the displacement inside Arnold Solaris ?
first issue is the subdivision scheme, it doesn't seems to work at all in solaris,
I tried to check the "treat as subdivision surface" on the sop import, tried to connect a edit property to the said sop import (adding catmull clark option parameter -from usd tab).
second issue is the displacement control itself, usually the parameters for driving it are on the geo node itself, I tried to import the arnold parameters to the sop import but as expected didn't do anything (SOP and LOP being two system I guess that's normal).
I have been searching every tut I could and couldn't find any use of displacement, is there someone to bright up my lantern ?
many thanks !!
Edited by legrandcolin
