time based lerp/conditions in VEX
hmihalis1
Hi everyone.
I'm hoping someone could take a look at this VEX and help me simplify it/point towards a more standardized way of handling time based conditions and blends in the DOP context, as I keep hacking together things to fill the similar requirements but it's always really over complex.
 'm searching for nearby points on prims in the 2nd input of this wrangle and if found snapping my position to the nearest point on that prim, plus adding a bit of the velocity. I want to start a timer from the time that the point is found and run that through two ramps; one to lerp the position and the other for the velocity.
Clearly its very convoluted and i'm also setting a lot of extraneous attributes, as I find if I try to use variables they often get reset each frame. It would be amazing if I could cut this number of lines in this down, or just get some tips on making it more readable.
Many thanks,
H
window_odforce.hiplc
