Lookup Tables In Vex
I have the following problem: In a VEX shader I have a fairly complex formula and rather then evaluating it each time I'd like to use a lookup table. As far as I know VEX won't allow us to to create an array containing ~500 entries.
There are currently two solutions I came up with though I don't like either one much.
i) Store a few values and use something like a spline interpolation (much slower then a lookup, though still more effecient then evaluating the 'big' formla)
ii) Using 4x4 matrices and building something like a binary tree with 'if - instructions' (fairly fast, but takes time to implement / time to write a small tool to automate it)
I don't like either solution much and wonder if anyone has come up with a smarter solution.
Jens
Jens
A texture map?
A DSO?
... if we assume that the "big formula" is complex enough that it's no longer just a matter of hallucinating a way to store its static data in VEX but also of accessing it efficiently...
Might as well do yer fancy binary/red-black/K-d/whatever storage along with all the number crunching over in C++ land, no?
If it's big/complex enough, then whatever overhead calling the dso might incur should become negligible by comparison (i.e: it should perform the fastest).
All solutions seem fine, thanks for the input.
I want to keep everything with VEX if possible and I like the idea using a texture to store the values most (basically I'm most familiar with that :P). However I have one problem.. getting the data into the texture. Is there a simple way to create a texture from data assuming I have created the appropriate r,g,b values to represent the data and have it in a text file? Like a two-liner with hscript ?
Writing a small program for that with java wouldn't be that much of an effort.. but :unsure: if I can avoid it, all the better.
