[SOLVED] Get point attribute value (string) in node parameters
JJ FX
So I have a string point attrib on a sop node, let's say it's s@this = "Yellow".
When I bring in the attribute into node parameters with houdini expression point("../node",  0, "this", 0) it always evaluates as 0 unless the string is empty s@this = "", then it evaluates as -1. So I guess point() doesn't see string attribs.
But what I need is a string and the exact value of that string! I don't care if it's houdini expressions or python, as long I can just get this attribute and use it inside node parameters!
Edited by JJ FX
