Turn a single faced primitive into 2 faces
Donny The Dealer
Hello everyone. As I've poly bridged my house model, I noticed each primitive only has 1 face. How can I make it so each side has its own face as it should? The Primitives I'm referring to are 635-643 (Between the ceiling and the wall)
 Thank you in advance to whoever can answer! :)
2.thumb.PNG.445856c1a161bed09b5bc370c87f7659.PNG1.thumb.PNG.69ab02a0c3b8ec872719481d8229db12.PNG
Edit: I'm thinking that I could poly-extrude the edges similar to what I did with creating the walls from the grid floor (which also had 1 face per primitive). I'll update this post if it works.
Edited by Donny The Dealer
speculating on idea
